I've been experimenting with the speeds of the fan on a Zalman 9500 CPU cooler to see how different speeds effect the temperature. I have an AMD 64 X2 4200+ CPU overcloked to 2.4GHz but also running Cool & Quiet so at idle it sits at 1.1GHz (I know that some of you will say i shouldn't overclock and run C'n'Q at the same time but I don't think there is any harm in doing so)
What I have found from my experimenting is that at idle (1.1GHz) there is only 1-2C difference if the fan is switched off (passive) or running at 100% and that's using Core Temp to read the temp, SpeedFan reported no difference at all.
When running at full load (2.4GHz) there was 2C between running the fan at 50% and at 100%.
This might not interest the serious overclockers for whom gaining 0.5C is prescious but for those who want a quiet PC I suggest you use SpeedFan and find out how fast your fans actually need to be running. At 50% speed the Zalman 9500 cooler is inaudible.
