Doing a dual loop build for first time, need a little advice on airflow.
26 Sep 2013
West End, Southampton
Hi everyone.
I'm currently building a little project, albeit rather slowly with stock levels. Now, I'm doing a dual loop system for this build and although I've been watercooling my rigs for years, done many systems, I've never done a dual loop system with 2 separate rads.
My question is really this. The top rad is always obviously exhaust out the top but if you've a rad in the bottom of the case, is it best to get the heat of the rad out the bottom of the case or to pull cold air in to cool the rad? The big downside of this way is that would obviously push hot air from the rad into the system which is always a big fat no no in my book.
So of these two examples, in your experience of running two rads or dual loop system, which is better to keep ambient temp in case to a minimum whilst also getting no or very little dust in the case.
Thanks in advance.
1st option
Or 2nd option.
I'm maybe wrong on this but I've never liked having hot air trying to go down. It's counter-intuitive. Hot air rises. If it's any help I would suggest having the bottom rad as an intake. Have another intake at least on the front if possible and the rear being an exhaust. The heated air (I won't say hot because it just won't be) from the bottom will get pushed to the rear by the intake cooler air and largely be exhausted by the rear. The front intake air will then be deflected upwards to the top rad. (is front intake even possible? Can't see whether the front is solid or not.)
With enough airflow through the case the internal temps won't be much elevated by the bottom rad being an intake. Assuming you're doing a gpu and cpu, use the top rad to cool the higher energy component.
Cheers Mike for the input. I've always done front and bottom as intakes and rear and top for exhausts as just like you say heat rises, the colder air will always be at the bottom. I just wasn't sure with dual rads if things are different. I've always done single loop single rad systems so only ever had fans blowing cold from front and bottom.
Btw option 2 has worked best for me BUT with the rear as intake, helped knocked a few extra degrees off the cpu temps.
Interesting. So having 5 fans as intake and 3 as exhaust doesn't give you a dust problem?
I'll start one up in the project channel.
My understanding is that more intake than exhaust, i.e. positive pressure, stops dust problems. The excess drawn air has to find a way out and does so through small gaps in the case. More exhaust than intake causes air to be drawn in through those small, usually unfiltered, gaps in the case.
Brilliant. Hadn’t thought of it like this. Thanks for the explanation.
@Jay85 nice. I’ll make the single fan position side and rear intake then.
