Hey guys
At some point today i will bet getting a EK P360 Performance Watercooling Kit and it will be the first time ive properly done a custom loop. Now ive done some quick research and everyone seems to suggest to flush/clean the radiators before first use.
Now i'm not sure how to go about this?! Use my hot water tap and flush it quite a few times until i see hardly any or no more debris or dirt come out, then do a quick couple flushes with distilled water?
That's what i'm thinking of doing and not sure if that's okay. Also do i need to add vinegar to the distilled water when i flush after using the hot water? To make sure i kill any bacteria and algae? Also does it have to be white vinegar or can it be the same sorta chip shop vinegar stuff?
Iv'e looked at the sticky "Custom Loop Guide" and will be following that as well as EK's guide.
Anyways i thought instead of waiting around ill just buy one when i drain it for the first time and then attach a drain port before i fill it back up with clean fluid. The res will be the lowest point in my loop. Turns out the EK rads are pre cleaned and even still ive cleaned my rad and found absolutely nothing came out. Water was clear first time. Flushed it 7 times with hot water. 5 times with tap hot water then twice with boiled water then flushed it a further 3 times with distilled water.
