doing my nut in!! help ?
16 Feb 2006
argh!
a little while ago i made a topic asking for help as my pc kept on dying when i using it and when i wasnt using it, it would just power off.
suggestions was that it was my ultra x PSU not be good enough to deliver power to my o/ced rig.
so i took the advice given and bough an enermax liberty 500W psu and after i plugged it all in and turned it on i got to hearing the lovely windows log in tune and it died straight away. also, it died during the night when it was just left downloading and just did it again when i was using msn and browsing this forum.
now i dont what else to think of !? i have bought a new, rated psu, have gone from 1.485 to 1.5125 volts of Vcore and am at 2.8V on the ram (said RAM is in sig, not sure what its rated at but its o/'d by 8mhz)
any suggestions as to what the problem is ??
What exactly happens?
Does it just power off/cut out or bsod?
Have you checked your error logs?
could have something to do with power saving mode? im guessing here....
or alternatively something in the bios?
i know im not being precisely but have you tried messing with the above? or finding out if those two are related to your prob?
in the performance folder theres counter logs, trace logs and alerts and there nowt for them bar the one sample log.
in event viewer theres stuff in the folders bar the security one but it dont make much sense to me/dunno what im ment to be looking for/error codes
Event viewer is your baby - try looking back thro them and see if anything 'interesting' seemed to happen around the time of your last shutdown experience.
It'll be in System or Application that you are wanting to look...
M
think may be something to do with it. its an error and it matches the times i started re-talking to a mate on msn (chat log) after it died on me
my pc said:
The COM+ Event System detected a bad return code during its internal processing. HRESULT was C0000005 from line 44 of d:\nt_qxp\com\com1x\src\events\tier1\eventsystemobj.cpp. Please contact Microsoft Product Support Services to report this error.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
the link offers nothing
nope, only errors i can see are the errors of death altho i got it three during the night but i was asleep for two (at 2am and the other at 3am) but when i woke up at around 5am the pc was on but died shorty after me waking up so this log is telling me my pc turned itself back on :confused:
Theres a setting somewhere so you can set it not to shut down on an error, but display a bsod instead so you might be able to get an idea of what the error is.
I can't remember exactly where it is tho...
Other than that, you should run memtest on it and prime 95 for a few hours.
Usual suspects with this sort of thing are psu and ram.
well it did it with my old ram, now running fine in mates pc and also does it with this ram (see sig) and did it with old psu (ultra x connect 500w) and did it with the new psu (see sig, did it first thin upon new psu, see top of page)
Nah, just bcause there is an error doesnt mean the PC turned off. You can get many errors that dont end in death.
Not even sure that the error there is the one causing the shutdown TBH.
M
Its possible that with the shutdowns that the PC doesnt have time to record the error.
Since you have that error at times when the PC hasnt shut down, it would tend to suggest that that error alone is not the cause.
M
good enough for me, the other at 5am is the same
This is a tricky one...
I'm beginning to wonder if it might be a software problem rather than hardware.
Is it possible to install a fresh copy of windows on it to find out?
You could install it on a different drive so you can easily go back to the old copy.
Dodgy driver perhaps.
