Dolby Digital Or LPCM
Permabanned
2 Feb 2010
Haywards Heath
I have connected up my Sony HT-XT3 up to my Sky HD box and my Sony blu ray player
Watching Sky T.V on most channels i get Dolby Digital format , but when i play blu ray dvd i get LPCM format
Is this normal ?
Yes, Sky is bandwidth limited so you end up with the compressed DD stream.
LPCM (basically uncompressed) is on Blu-ray because space isn't of a concern.
You may find the blu-ray player has an audio option for bitstream.
LPCM means the player is doing the encoding, when you get DTS-HD etc on your amp then the amp is doing the processing. I like to have bitstream on so I can see what audio I'm actually getting.
I have changed all settings on blu ray player but still comes up LPCM on amp not Dolby Digital , when watching Sky its saying Dolby Digital
Looked in menu on blu ray player , i have set Digital Audio Output to " Auto " the other option is PCM
Other settings i did change was Downmix to " Surround "
LPCM IS UNCOMPRESSED
Why do you WANT a compressed audio stream over an uncompressed one?
Uncompressed :rolleyes:
They're both uncompressed/lossless, as Nick said LPCM is the player doing the decoding and bitstream the amp is decoding.
I always bitstream from my 4k player as I also like to see what audio I'm getting.
Thehitman LPCM or bitstream it'll still be DD or DTS you're listening to.
DD (Dolby Digital) is not lossless. Neither is DTS.
However, their "HD" equivalents (Dolby TrueHD and DTS-HD) are considered lossless. They are still compressed, but the resulting sound when uncompressed should be indistinguishable to the original.
LPCM is uncompressed audio.
Whether the decoding is done on the player or the amp should be inconsequential in terms of what you hear. The only difference is what you see on the front of the amp.
i believe you have to bitstream from the player if you want dts:x or dolby atmos, so there's that. On the flip side, if you like secondary audio then LPCM from the player is better otherwise the audio gets down-res'd. So it's not quite as clear cut as use either because they're both the same.
