Dolphin browser not loading some images
ajf
ajf
30 Oct 2006
Worcestershire, UK
I use Dolphin browser on my Note 8 and find some images arent displaying.
Typical example is the 'recent purchases' thread in GD.
it seems to be mainly photobucket hosted images.
If I use Firefox they are fine, but I prefer Dolphin as a browser.
Any ideas?
I've tried turning flash on and off - I loaded flash manually as not part of Android 4.1.
Javascript is enabled.
I've also tried changing the user agent it emulates between android, desktop and iPad.
Tried that too.
It is a really annoying problem but just cannot get to the root of it!
I had issues with images not loading and links not triggering. I love dolphin but ended up switching to boat browser because of it.
Everything works great for me on my Galaxy s3. Do you have any Dolphin add-ons/extensions installed which may be causing some sort of conflict? If yes you could try disableing or uninstalling them to see if that sorts the problem.
Other than that, it might be worth trying out the beta version to see if you get the same problem.
https://play.google.com/store/apps/details?id=com.dolphin.browser.lab.en&hl=en
I had the same problem and disabling / enabling jet pack fixed it. Can't remember which way round as other issues such as the cursor keys not working in replying to threads, made me ditch it.
I think I might have a couple of add ins installed actually, and I am pretty sure Jetpack is installed too - though not actually sure what that was supposed to do!
Might just try removing them all from the tablet then just adding the browser again for the time it takes.
Just switch off jet pack from the settings menu. That's what sorted it for me. Unfortunately this also disable the cursor keys on my SwiftKey keyboard for some god forsaken reason.
Thanks.
Disabling jetpack worked :)
Must admit I just installed it as it was recommended but not enitirely sure what it does. I assume it adds new web capabilities?
