Dolphin Wii Emulator
Status
Not open for further replies.
17 Nov 2008
Anybody else here use Dolphin? I only discovered it recently after IGN sang its virtues. Itll play the vast majority of Wii games and output them at 1080p seriously improving the graphics. Ive had 2 Wii's and never got on with em after discovering i was actually a graphics tart and finally giving up on em but this cures that Wii blur o vision, some of the stuff like Another M look really good. You need a pc with bluetooth to link the wiimote to pc and a wireless sensor bar and thats it. Download your Wii iso's and your away! You need a little bit of horsepower to run it, ive got a stock 920 i7 with a GTX590 in desktop and a M18X with a i7 2820QM, CF 6970M and both run it perfectly. Its supposed to be more CPU intensive than GPU and allthough both those CPUs are good there not overclocked so i think if you have any i7 or i5 with a comparable GPU you should be ok.
I'm sure Dolphin is a fine emulator, however it's a grey area as it generally advocates piracy. I'm sure you have the original copies of the games you're playing, but on these forums discussion of them isn't allowed :(
Status
