Caporegime
- 13 May 2003
- Warwickshire
I have a few electrical jobs that I need to do and although I'm not practiced in domestic electricity, I've done a lot of other DIY, have a basic knowledge of circuits, and have read a lot and am confident that I can tackle it.
Please could a kind person let me know which of the following am I allowed to do myself?
My thoughts are to wire the fan to the shower circuit as was (which has a di-pole isolated switch thing and its own circuit back to the RCD etc.) so that I can control the fan independently of the bathroom lights. The RCD has a 40A fuse on this ring...so presumably I'd need to swap that for something lower? And if so, what?
Many thanks! Oh and if anyone has any good links for explanations of domestic wiring, I'd be grateful . I've been reading about junction boxes but I'd find it easier to wire from existing roses, because there's a lot of insulation in our roof.
- Add new power outlet in main bedroom
...by spurring off a power outlet already in the main bedroom. Plan is to run 2.5mm2 cable under the floorboards to the other side of the bedroom.
- Install 2 x LED spotlights in bedroom ceiling
...above location for fitted wardrobe. Haven't found a suitable rose yet, but again the plan is to spur off the current upstairs lighting circuit. Switch-wise, it's going to be a pressure switch that switches the lights on when the door is open.
- Install extractor fan in main bathroom
...in place of a current spot light. I would have just had the fan coming on with the spotlights (which would presumably have made things simpler?) were it not for the fact that there's a spare power cable for the old electric shower hanging around not being used.
