Dominos stuff crust pizza
EDIT: Apparantly not. Weird, I always assumed it was.
They also have a base that basically uses two bases with a layer of cheese between them.
How much more does a stuff crust then just a normal base? I didn't know it went inbetween the bottom base and a second base.
£2.50, it doesn't if you order stuffed crust then it comes in the crust like pizza hut, if you order the dominator or double decadence it comes with the sauce between 2 bases with the topping on top of the 2nd base. The difference between the 2 is one uses a thin crust on top of a normal crust and one uses 2 thin crusts.
I see thanks for the heads up. no hard feelings but, I must say I do love the contrast between what you replied to me and your sig. The fast food and the "journey out of obesity". :D hope that has gone well.
Wait, you realise they do stuffed crust rather than base now :p?
The garlic and herb sauce is disgusting =<
Cheers for replies.
How do you think I got there in the first place :p I also had a little smerk when I seen what I'd written with my sig :D
