- 29 Mar 2008
Many thanks to the threads on this forum and others I took a crash course in overclocking over the weekend. A few concepts take a re-boot or 3 to lodge in the grey matter but I'm getting the basics (he hopes)
So far I've got a gigabyte GA-P35-DS3L motherboard with Intel Quad 6600 and 2x2gig OCZtech PC2-6400DDR2) to run at 3.4Ghz. Core temps on full load are 55deg. So far, steps are (all done incrementally and tested)
If I go above 380mhz on the FSB (via BIOS) it fails to run past BIOS, the BIOS resets to disable the manual control on the FSB and resets to 266mhz. Obviously this isn't temp related as it's only just booting so I was wondering which bit of the system is preventing it from running faster? Memory timing is set to 4 4 4 12 which from what I have read is ok on this RAM
As I said, I'm a newbie to the art of this and shunned the gigabyte windows software which gave me such vague options as 'turbo' and 'extreme' etc. I've done it all from the bios and tested each step as recommended.
It's not a moan...3.4 on a 2.4 chip with 14800 score on 3dmark6 (8800GT) isn't sluggish but, you know, it's like car tuning...if you think there's some more in there...you want to find the limit (just...it's easier/cheaper with a PC than a twin turbo GTR when you overcook the 'boost')
When it gets to temp problems then that nice all in one water cooling kit I've seen on the site looks appealing but for the mo, just wondering what is causing it to fail
any help appreciated
Ben
- Increase FSB to 380mhz (9x multiplier on CPU giving 3.4ghz)
- increase core voltage to 1.4V (showing 1.36 on CPU-Z)
- Increase memory voltage by 0.4 i.e 2.2V
- Reduce FSB
RAM to 1:1 as 800mhz DDR2 mem
Ben
