Dont know root password - help !
17 Jan 2006
Dundee
I'm trying to resolve an issue here with a laptop with ubuntu 10.10 on it. A colleague of mine installed it for a friend but failed to tell him the root password, not my colleague is overseas for a few weeks and I'm left trying to resolve this issue.
Any ideas as to how I can change this password.
Don't know of any way to change the root password that doesn't involve knowing the current one. However, if your colleague didn't tell the friend what it was its unlikely to be a complex one. So it should be guessable. I'd tru the following.
1. root
2. toor (i.e. root reversed)
3. The friends name - all variations of first and last name.
Good luck,
vfm
its the log that holds the passwords for all wifi connections on your OS, so you only have one master password to unlock the keyring, rather than re-entering the pass for every connection when you roam.
As already mentioned, Ubuntu has sudo configured out of the box so you shouldn't ever (in theory) need to use the root account. To perform superuser functions you type in "sudo commandname" and supply the USERS password. In-fact, can you even log in as root in Ubuntu?
You need to set a root password, and then do a manual login :) (Doesn't appear in the list of users in GDM)
-Leezer-
