Don't know what wattage PSU
9 Jul 2008
Bristol
Hi,
I am stuck on choosing a PSU for my new build. I think 1K is a bit overkill for mine, but I am not sure.
What WATT Psu should I get?
Specs as following:
I7 920 (Will be overclocked)
A Gigabyte mobo
Geforce 295 (Might Overclock)
XFI Sound card
Hard drives will be either 4 x raptors for raid and 1 500GB for storage or 2 x SDD RAID + 500GB storage
About 8 FANS
CPU, GPU and MOBO will be watercooled.
I hope this is enough info
Thanks for reading
SLi is your main wattage killer. 700-800 would be fine for the system you have at the moment, particularly if you use SSDs instead of 4 raptors. If you want to SLi 295s, you're looking at 1kW.
Well the SLI has not been decided yet, it depends on how much money I will have once the whole PC is build!.
But I don't want to get a 800W PSU and then decide to go SLI and get a new PSU
