dont laugh, need GRAW 2 help very fast
basically you have to kind of move around the structure be it the bridge or a tank. The C4 graphic moves around the structure with you and at some point a message comes up and says plant C4 by pressing your use key (or something like that)
The problem is that there seems to be a sweet spot and it can be a bind to find.
nope, ive just scanned the entire thing with the clear c4 looking object and nothing!!! fustrating!!!
ags
Basically if you see a yellow c4 icon on the plantable surface it will ask you to press X (default) you need to hold it down to plant the c4, then run away to a safe distance and press x to detonate it.
sussed it when i got really close, it said it, i was standing about a metre away just looking around it waiting for it lol
ags :D this game is awsome, now on the second level with the sniper, SOOOO much fun, love getting into positio then sending my team in as a distraction then owning all the 'bogey's'
ags
Not necessarily, he could have imported it. Anyways, I can't wait to play the full game, first one was a blast.
Multiplayer is pretty decent too but the community seems to be lacking. Hopefully GRAW 2 will revive things a little.
