Doom 3 16x AA?
22 Jun 2004
London
Howdy,
Just a quickie, how many of you out there can play Doom 3 (or RoE, that's what I am playing) on 16x Anti Aliasing? I know its higher than what you would ever need, but I get major FPS slow down on that, and just wondered how many others out there got this? Mainly using a 8800 series card?
I get 60 FPS all the time on 4x and 8x (most of the time) but 16x is a killer!
Just curious thats all!
ta
willhub said:
I am using 16xQAA here and my lowest is 30fps but I am running at 1440x900.
Im running it at 1920x1200, I suppose that makes a diff. I just thought my rig would be able to run this better... its not the newest game after all?
Yes even at that res I guess you should be able to run Doom 3 at 16xAA, afterall, I dont think its that impressive really and dont notice much difference from High and Ultra quality.
What other games can you run at 1920x1200 with 16xAA?
I really need to start trying out some of these more interesting modes.
How does it scale? Especially when you enable multi or super-sampling in the transparency AA box..?
Last time I used Super Sampling in a game it was a massive performance hit, havent tried Doom 3 tho, gonna try it now :D
I actually cant think of any other games that allow me to go to 16x tbh? FEAR lets me go to 4x (that runs PERFECTLY on everything high) but all my other games dont go to 16x? Can you think of any, I might have it and give it a try?
You can force 16xAA/AF/QAA with the Nvidia Control Panel.
Damn Doom 3 wont even load for me now :o
Code:
2797 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2 & SSE3
1024 MB System Memory
640 MB Video Memory
Winsock Initialized
Hostname: 880037001gbts
IP: 192.168.0.2
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Current search path:
H:\Games\Doom 3/base
H:\Games\Doom 3\base\pak004.pk4 (5137 files)
H:\Games\Doom 3\base\pak003.pk4 (4676 files)
H:\Games\Doom 3\base\pak002.pk4 (6120 files)
H:\Games\Doom 3\base\pak001.pk4 (8972 files)
H:\Games\Doom 3\base\pak000.pk4 (2698 files)
H:\Games\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
4966 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
execing DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (1280x1024)
Initializing OpenGL driver
...getting DC: succeeded
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: The current video card / driver combination does not support the necessary features
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Anyone have any idea what this error report means? I wonder if its these 160.03 drivers doing this :confused: Was working ok last night with these drivers, then I enabled 16xQAA and SS and now it never works even with them turned off O_o
Blokey57 said:
i may be wrong, but only having a gig of Ram may not help? :)
Well yea 1GB ram dont help but it should not stop the game from running when it has worked before.
It's because ultra quality needs 500mb of video memory according to John Carmack, with 16xAA adding a good deal more at high-end resolutions.
I get the same amount of lags in 16x in High quality as I do in Ultra quality. Actually doesn't make any difference in performance wise from what I can see?
willhub - I got an error on the game, when I had patched D3 to 1.3.1 and then installed RoE. I had to reinstall the 1.3.1 patch and it all worked again.
Don't think it was the same error as that though, but you can give it a go!
I dont see why the textures in Doom 3 and Quake 4 need 500+ memory, you get better textures in games like F.E.A.R and it dont even need that much video memory :o
Ah great will give it a go, havent bothered to patch Doom 3 :p
Ok, I got it working now, just went back to the 158.22 drivers :)
I just tried it out with 16xQAA/16xAF with Supersampling, sometimes it was well over 60, lowest I got was 35 when I looked up at that hovering thing at the start.
Hmm Doom 3 is capped at 60fps, you shouldn't get more? And if you are getting great FPS, why am I not? interesting, I must investigate!
cheers for checking though, appreciate it!
Yea Doom 3 is capped at 60fps but the cap can be removed, I think the reason its so low for you is because of the such high screen res, just turn the res down to test if it is, also go into the Nvidia Control Panel, then go to Manage 3D Settings, were it says, Multi Display/Mixed GPU Acceleration, change it to Single Display Performance mode, when I had it to Multi Display the game was unplayable.
Does anyone also know how to enable Widescreen res in Doom 3 (1440x900)?
K I will give it ago.
To get widescreen, create a "AutoExec.cfg" file in the "base" directory of Doom 3 with the below contents:
set r_mode -1
set r_aspectratio 2
set r_customwidth 1920
set r_customheight 1200
Thats what I have, and its the only way to get widescreen... but I don't think its proper widescreen. It works nonetheless.
r_mode tells doom its a res that is not selectable, the ration option sets it to 16:10 and the other 2 are self explanatory.
Inoshishi said:
Just to add to the above
r_aspectRatio can be set to 0, 1, or 2 (4:3, 16:9, 16:10)
Yep, I didn;t bother witht hat, cos I didn't think he would be interested in the other ratios... but it was worth pointing out actually :)
It does need that much on Ultra, and more if you start whacking up the AA Quake 4 textures are very high and very nice! Look at the character detail next time you play.
So only 1GB of RAM will be a factor in the lower frame rate
:p
