Doom 3 mods?
9 Jun 2006
Purgatory
Recommend me some Doom 3 mods :) I am playing it for the first time. Graphical and gameplay enhancements appreciated.
Any way to play it on Steam version?
DOOM 1.3.1.1304 win-x86 Jan 16 2007 15:36:51
3402 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & HTT
4096 MB System Memory
768 MB Video Memory
Winsock Initialized
Found interface: {981A5067-6C20-42FD-984F-47B16801AF5A} Broadcom 802.11g Network Adapter #2 - 192.168.1.68/255.255.255.0
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\game00.pk4 with checksum 0x29cdb978
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\game01.pk4 with checksum 0x51c6981f
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\game02.pk4 with checksum 0xf3ec6f7
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\game03.pk4 with checksum 0x5d4230ea
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak006.pk4 with checksum 0x95b65ab
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak007.pk4 with checksum 0x666bdb3c
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\base\pak008.pk4 with checksum 0x23ae5993
Current search path:
c:\program files (x86)\steam\steamapps\common\doom 3/base
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak008.pk4 (3 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak007.pk4 (38 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak006.pk4 (48 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak005.pk4 (63 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak004.pk4 (5137 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak003.pk4 (4676 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak002.pk4 (6120 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak001.pk4 (8972 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\pak000.pk4 (2698 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\game03.pk4 (2 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\game02.pk4 (2 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\game01.pk4 (2 files)
c:\program files (x86)\steam\steamapps\common\doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5206 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
execing DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
Setup OpenAL device and context... Done.
OpenAL: found EAX 4.0 extension
OpenAL: no EAX-RAM extension
OpenAL: found SB X-Fi Audio [D000]
OpenAL: found 123 hardware voices
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (1680x1050)
Initializing OpenGL driver
...getting DC: succeeded
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
...using GL_ARB_multitexture
...using GL_ARB_texture_env_combine
...using GL_ARB_texture_cube_map
...using GL_ARB_texture_env_dot3
...using GL_ARB_texture_env_add
...using GL_ARB_texture_non_power_of_two
...using GL_ARB_texture_compression
...using GL_EXT_texture_compression_s3tc
...using GL_EXT_texture_filter_anisotropic
maxTextureAnisotropy: 16.000000
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
...using GL_EXT_texture3D
...using GL_EXT_stencil_wrap
...using GL_NV_register_combiners
...using GL_EXT_stencil_two_side
X..GL_ATI_fragment_shader not found
X..GL_ATI_text_fragment_shader not found
...using GL_ARB_vertex_buffer_object
...using GL_ARB_vertex_program
...using GL_ARB_fragment_program
...using EXT_depth_bounds_test
---------- R_NV20_Init ----------
----------- R200_Init -----------
Not available.
---------- R_ARB2_Init ----------
Available.
----- R_ReloadARBPrograms -----
glprogs/test.vfp
glprogs/test.vfp
glprogs/interaction.vfp
glprogs/bumpyEnvironment.vfp
glprogs/ambientLight.vfp
glprogs/shadow.vp
glprogs/R200_interaction.vp
glprogs/nv20_bumpAndLight.vp
glprogs/nv20_diffuseColor.vp
glprogs/nv20_specularColor.vp
glprogs/nv20_diffuseAndSpecularColor.vp
glprogs/environment.vfp
glprogs/arbVP_glasswarp.txt: File not found
glprogs/arbFP_glasswarp.txt: File not found
using ARB_vertex_buffer_object memory
using ARB2 renderSystem
WARNING: SetDeviceGammaRamp failed.
found DLL in pak file: c:\program files (x86)\steam\steamapps\common\doom 3\base\game03.pk4/gamex86.dll
copy gamex86.dll to c:\program files (x86)\steam\steamapps\common\doom 3\base\gamex86.dll
game using MMX & SSE & SSE2 & SSE3 for SIMD processing
--------- Initializing Game ----------
gamename: baseDOOM-1
gamedate: Jan 16 2007
Initializing event system
...473 event definitions
Initializing class hierarchy
...142 classes, 191092 bytes for event callbacks
Initializing scripts
Compiled 'weapon_pistol::Raise': 637.2 ms
---------- Compile stats ----------
Memory usage:
Strings: 79, 9648 bytes
Statements: 67875, 1357500 bytes
Functions: 2109, 250532 bytes
Variables: 147376 bytes
Mem used: 2476344 bytes
Static data: 2277552 bytes
Allocated: 3281600 bytes
Thread size: 7068 bytes
...6 aas types
game initialized.
-------- Initializing Session --------
WARNING: idChoiceWindow::InitVars: gui 'guis/mainmenu.gui' window 'SNDBPrimary' references undefined cvar 's_driver'
session initialized
--- Common Initialization Complete ---
------------- Warnings ---------------
during DOOM 3 initialization...
1 warnings
guid set to zi2FA1cfA0E
============= ReloadEngine start =============
--------- Game Map Shutdown ----------
Shutting down sound hardware
idRenderSystem::Shutdown()
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
------------ Game Shutdown -----------
Shutdown event system
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\GTX\game00.pk4 with checksum 0xf8a67630
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\GTX\pak001.pk4 with checksum 0xf4a37381
Loaded pk4 c:\program files (x86)\steam\steamapps\common\doom 3\GTX\pak002.pk4 with checksum 0xf26e187
c:\program files (x86)\steam\steamapps\common\doom 3/GTX
c:\program files (x86)\steam\steamapps\common\doom 3\GTX\pak002.pk4 (364 files)
c:\program files (x86)\steam\steamapps\common\doom 3\GTX\pak001.pk4 (737 files)
c:\program files (x86)\steam\steamapps\common\doom 3\GTX\game00.pk4 (3 files)
Addon pk4s:
background thread already running
execing editor.cfg
execing default.cfg
execing autoexec.cfg
...initializing QGL
...calling CDS: ok
Not available.
Available.
glprogs/test.vfp
glprogs/test.vfp
glprogs/shadow.vp
found DLL in pak file: c:\program files (x86)\steam\steamapps\common\doom 3\GTX\game00.pk4/gamex86.dll
copy gamex86.dll to c:\program files (x86)\steam\steamapps\common\doom 3\GTX\gamex86.dll
0 0 1680 1050
Regenerated world, staticAllocCount = 0.
wrong game DLL API version
I get that when I select it from the mod menu :(
gamex86.dll
Is your problem there are 2 or 3 different versions of this file on various ID & Activision games from 2003/2004. GTX mod only works when you use a certain file version so you will need to find out which one sorry but I do not remember other than having to trawl through my games to find the working version.
I got a similar error too. But I think its cos I was running patch 1.3.1 Uninstalled doom3, reinstalled and installed patch 1.3, mod now works ok.
But! Blimey with the new graphic settings the single player makes my pc crawl :(
Just downloading the 'lite' version.
FlyingFish wahts your pc specs.? Im just dl'ing this now and am curious.
I have sig in rig and am wondering what i can expect.?
I played Q4 with everything maxed out on ulimate settings 1280x1024 and managed a steady 60fps.
Core duo thingy clocked at 3.1ghz AC7
2GB Ram
Asus P5Q Pro mobo
ATI 4850 512mb
XP Pro
32" HD tv @ 1360X768
Funny thing is Crysis runs smooth on full at this res, and now seeing Doom3 crawl is a bit amusing :eek:
Just gonna try the lite mod.
Mick
OK still a slide show, seems to be the flying space ship at the start and also the first entrance/scanner.
Turned AA down to X2/Box
MipMaps down to quality
Adaptive AA off
Still Cr@p
Think I'll give this mod a miss :(
BTW: Running CAT 8.6 drivers.
Mick
Yep mod slide show for me on 4850 as well but on my old 8800GTX the mod flys so guess its optimised for Nvidia cards.
