Doom 3 Mouse Lag
12 Mar 2006
N.E England
Ok playing through Doom 3 on with the spec in my sig
Ultra settings
16xCFAA
16xAF
In some parts of the levels I get an odd mouse lag yet the fps seems to stay on a dead 60fps, the FPS has only dipped to around 40fps a few times otherwise. It almost feels like mouse smoothing but I have that disabled from the menu. Can anyone shed some light onto this. Loving the game so far, can't believe I didn't play it sooner :D
Is it V-Sync?
I get terrible terrible mouse lag with basically any game when I have it turned on.
Might be worth checking your refresh rate as sometimes running framerate and refresh rate out of sync can make things feel laggy. I don't mean you should be running vsync (quite the contrary), just that with D3 limited to 60fps you might like to try a refresh rate of 60hz.
try upping your refresh rate, having a crt handy to test would be helpful, a few people complain of this and seems running 85hz+ cures it.
I know its already been said but it really really sounds like a v_sync issue. Even if its off in windows are you sure theres not a setting in the game for it thats enabling it? you might be able to trick it by setting maxfps @ 45fps..and if your fps then drops to dead on 30 (half of 60) ..v_sync is secretly on :)
