- 6 Jan 2009
I have just put together a system (in sig) and already people are saying I should get more memory, etc...
I wasn't sure about Windows Vista but I was told more games would run on the 32-bit version, I was told the 64-bit version was better. The 32-bit would only see a maximum of 3.5 gig RAM and the 64-bit version would need a lot more.
I personally think my system should be good for at least 12 months before it needs hardware additions. And maybe my system will work great with Windows 7.
It just bugs me how I thought I had it right, but some folks say I'm missing the mark. How many times do you put a system together on paper, then you spread the wedge before Nigel the Nerdberger pulls off a frontside bus triple channel giganazi cracker jacker punch to your nads?
What do you think? I'm sure I'm not the only one out there that is upgrading and is getting mixed messages. Does my system need more ram, etc? Because my wallet isn't infinite. But I can take bread out of my childrens mouths because I don't have any.
-thanks
-thanks
. Have to get someone else to answer if another 3gb is a worthy peformance gain for the price
