- 18 Feb 2004
- Lincolnshire
Code:
[DoS Attack: TCP/UDP Chargen] from source: 45.119.86.210, port 49131, Friday, August 13, 2021 13:23:15
[DoS Attack: RST Scan] from source: 185.206.180.182, port 80, Friday, August 13, 2021 13:01:48
[DoS Attack: SYN/ACK Scan] from source: 162.241.216.182, port 443, Friday, August 13, 2021 12:21:12
[DoS Attack: SYN/ACK Scan] from source: 162.241.216.182, port 443, Friday, August 13, 2021 12:01:58
[DoS Attack: SYN/ACK Scan] from source: 162.241.216.182, port 443, Friday, August 13, 2021 10:41:38
[DoS Attack: TCP/UDP Chargen] from source: 184.105.139.117, port 39455, Friday, August 13, 2021 09:30:18
[DoS Attack: SYN/ACK Scan] from source: 193.126.27.67, port 443, Friday, August 13, 2021 09:26:22
[DoS Attack: TCP/UDP Chargen] from source: 8.8.8.8, port 53, Friday, August 13, 2021 09:20:21
[DoS Attack: TCP/UDP Chargen] from source: 8.8.4.4, port 53, Friday, August 13, 2021 09:20:21
[DoS Attack: TCP/UDP Chargen] from source: 8.8.8.8, port 53, Friday, August 13, 2021 09:20:14
[DoS Attack: SYN/ACK Scan] from source: 193.126.27.67, port 443, Friday, August 13, 2021 09:00:18
[DoS Attack: SYN/ACK Scan] from source: 193.126.27.69, port 443, Friday, August 13, 2021 08:14:51
[DoS Attack: SYN/ACK Scan] from source: 120.78.39.132, port 9797, Friday, August 13, 2021 08:11:31
[DoS Attack: SYN/ACK Scan] from source: 193.126.27.69, port 443, Friday, August 13, 2021 07:52:32
[DoS Attack: TCP/UDP Echo] from source: 141.212.123.207, port 59823, Friday, August 13, 2021 07:26:42
Is the above a problem for my connection in terms of using it and security?
The ip addresses seem to be related to somewhere in America.
https://ipinfo.io/162.241.216.182 - Houston Texas
https://dnslytics.com/ip/162.241.216.182
Then one is in Germany ?
45.119.86.210 - https://ipinfo.io/AS131386/45.119.84.0/22 - Vietnam
