dosh to spend ..
Mav
Mav
3 Nov 2005
Kingston Upon Hull
Hi all ..
i`am in 2 minds which way to jump for a upgrade, i have in mind 2 choices atmo ones a cheaper option an the other is a full on upgrade ..
I`d like to hear anyones opinions on the pro`s & con`s to help me decide ..
i`am realy not after Oc`ing either set up .. also i`ve picked the 4 gig of ram
for a x64vista upgrade later on .
With thx in advance ..
If you're not clocking why have you chosen RAM that you won't even use to it's full potential? and the aftermarket cooler isn't really needed either if your not clocking.
Something far more sensible.
much better option
Cheers "chopper" i was thinking ppl don`t read posts properly ;)
the 4 gig is for a x64 VISTA upgrade later on ..
The after market cooler is because i like to keep my systems as cool as possible an i`am no to keen on stock coolers,
noise an cooling is not normaly there strong points ... ohh an the Intel chip is OEM aswell ..
I suppose the 2 cpu`s i`ve picked are the best either AMD/Intel offer at the mo ..
i`am after something that`ll run SupCom for instance better than what i`ve got now ... an seeing as it`s a more CPU based game than graphic, thats why i`am not bothered yet about changing my VGA card yet.
tbh, i would recommend the intel 1, because i never had amd, but thats my choice, if you wish to buy that 1, i would unless some one can come out with a spec neally the same, but cheaper?
