Dot and dab and a bracket.
27 Feb 2013
I like to put up a TV soon and I have a external wall with a dot and dap. Whats the easiest way to put up a bracket on these. Bracket is for 55 lcd screen.
Im not a builder but cant I just screw into the plaster board and into the brick. I know outside is stone work but will there be brick in the inner side of the wall? Couldn't imagine drilling into stone. Im not doing it myself but just need to know where i stand with this. Regards
I'm not familiar with the term dot and dab, will there still be battens? If so find those
Where the surface finish is dot 'n' dab, then it's most likely that your wall construction is an outer skin of brick or stone, then an air gap probably filled with insulation, then an inner skin of brick or more likely some kind of block work such as aerated- or breeze-block.
For those unfamiliar with the term dot 'n' dab: The options then to make the final finish are either wet plaster comprising of a base coat plus top coat skim, or plasterboard sheets fixed in place with blobs of plasterboard adhesive dotted across the wall, then the board pushed on to the adhesive. This latter is dot 'n' dab.
After the joints have been taped and skimmed, the result is a smooth wall finish that was quicker to apply and used less materials than a traditional wet plaster finish. Dot 'n' dab is useful where there's an uneven wall surface such as rough brickwork or for where there's a need to square up the room because the the block work means that the opposite walls are not parallel.
The catch is that there are gaps between the back of the board and the wall in the spaces between the adhesive blobs. Where these gaps occur, the board surface can't support much pressure from a wall fixing. A traditional wall plug and screw through to the block behind will collapse the board in to the unsupported gap.
@lost0ne33 - depending partly on what's being hung, you have a couple of options.
The plasterboard between the adhesive blobs will be quite strong so long as you're not fixing on a joint. Gripit fixings can be used where a flat TV bracket or one with a small amount of tilt is to be hung. Once in place, most of the TV's weight is acting vertically so the fixings aren't going to move. If you decide to go with Gripits then you'll use them where there's a gap behind the board because of the way it anchors. (Once you see the wing design then this will make sense.) It's unlikely though that every fixing point will hit a gap if you're spreading the load evenly. This means you will inevitably hit a point where the board is sitting over a solid blob of adhesive. At these point use a basic wall plug and screw fixing as if you are fixing through plaster directly over brick.
For brackets that involve an articulated arm then the loading is more complex. You need something that will withstand a lot of pull and push force acting in the direction of the fixing. You also need a fixing that will transfer the weight to the block behind so that the board surface doesn't collapse in. In effect, the fixings become pilings sitting just slightly proud of the board surface. A good solution for this is Rigifix. Use the M6 size. They are more than sufficient for hanging over 100Kg. Don't be tempted to use the M8 size. They're overkill for a TV mount, even for a full motion bracket.
I got the smaller arm of the same make for my 55" OLED LG and put it up on a dot-n-dab wall. It came with the fixings and rawplugs needed, I just drilled through the plasterboard till I got to the breeze block behind.
This is the arm I got: https://www.amazon.co.uk/gp/product/B01AYB3MD6
i have that for my 43" it's crap compared to the other one for the sake of a tenner
i own both of them
For a heavy duty fixing into dot n dab I'd definitely choose Corefix. They can be found in smaller packs than the one linked to above, but they really are secure. I fitted some kitchen wall units with them and they can easily take my weight.
Shrug, worked fine for me :)
yeah it's good but the other one is really good, i'm sure it will work fine but IMO best to spend the extra tenner as it's longer, better articulating, more secure, etc. i know someone who spent like £250 on a bracket which is similar to the £40 one. there's is better but not £210 better. so it's still cheap and I don't think the £10 saving warrants it especially if you are using it for a decent tv.
like i said i bought the smaller one for the 43" because the bigger one wouldn't accommodate a tv that small.
Belt and braces is good, I think because my TV is only 24kg I felt ok with the smaller one, good to know you recommend the other one though, if I need to replace this one I can just get that instead.
For my 65" TV I went for the official LG low profile one as I don't need any tilt/swivel.
Anyway relating to the OP's question, did you not find the supplied raw plugs and bolts not sufficient? I thought they were pretty beefy and spot on for what they had to hold.
