1st build in 4 years so I am rusty and very nervous of making an ass of it.
Corsair 600T case
Asrock X68 Gen 3 Motherboard
OCZ 850 PSU
H100 Cooler
So far I have connected the following
24pin power
8pin power
Rear case Fan - Power Fan 1
Front Fan - Chas Fan 1
2 x Rad Fans - H100 Unit
H100 - CPU Fan 1 & Connected to PSU
2 x USB 2.0 - USB Headers
HD Audio - Audio header
1394 - 1394 Header
Unknown power cable from front of case - PSU
SSD - Sata 3-0 Grey & PSU
HDD - Sata 3-1 Grey & PSU
Optical Drive - Sata 2 black & PSU
I still have the power headers to connect which I am okay with but I have the following spare as such
USB 3.0 cable from case
4 x unmarked 3-pin cables from the front of the case
1 x fixed 8 pin cable from PSU that can be split into 2 x 4
The case also comes with a USB3.0 backplate - is this worth installing ?
If someone could cast there eye over it to see if there are any basic errors with what I have done so far and where any of the spare ones should go.
Want to make sure I am okay before starting on the Graphic cards.
Thanks
Corsair 600T case
OCZ 850 PSU
H100 Cooler
24pin power
8pin power
1394 - 1394 Header
Thanks
