double check this is fine?
23 Jan 2010
St helens
Gigabyte GA-Z77X
i want this board so i can use 3 gpus , now i notice it only has 1 x 4 pin power input longside the normal plug, now i thought that it would have had a 8 pin ? i know gpus have there own powersupply inputr but dont they use some from the board aswell?
if its better to go for something else ill go for this
Asus P8Z77-V LX Intel Z77
sell my current gpu and buy 2 better cards, i prefer to use the gigabyte if its fine as the gpu i have is currently quite cheap and buying 2 more wouldnt cost to much
What is your current setup? What CPU will you be using?
I would try and find a motherboard with a 8-pin UPS connection. It helps with over clocking aswell as GPU performance.
