Hi all
I have been reading up on watercooling recently because of how hot my 470 gets. Now I also thought that if I am going to go through the trouble of creating a loop for my gpu I might as well remove my H50 and add in my CPU to the loop. I will also be overclocking my cpu, hopefully will be able to get 4Ghz but will see how far I get before temps take over.
Initial plan for loop is
res -> pump -> 360 rad -> cpu -> 120 rad -> gpu -> res
OR
res -> pump -> 360 rad -> 120 rad -> cpu -> gpu -> res
My hope is that with an 120.4 of radiator I should be able to run the fans quite slowly and reduce noise.
A few questions I have which I hope you can answer
1. Is it better to run the same fans on the radiators or is it ok to run different fans? At the moment I have a 2 cooler master fans, 2 akasa vipers and an akasa ultra quiet. So I could use a mix of those fans on the radiators or pick up some yate loons or scythe GT's.
2. Is this spec alright for cooling my set up with reasonably low rpm fans? (fittings might change depending on final loop)
Edit: 3. If I leave the standard 230mm fans in the front and side, can anyone forsee a problem with air cooling my motherboard as I wasn't going to watercool it.
Thanks for the help.
OR
I will look into those 2 rads though to keep order together.
well you can but if you can keep them in the case then you should be ok
My limiting factor is I want to keep it all inside, though had my case open for troubleshooting tonight, I need to measure but I might have enough room for another 120 rad in my spare 5.25 drive bays. A bit overkill possible but every rpm slower I can run fans the better.
