Hi all,
Just a quick question as struggling to find some answers. We had double glazing fitted in our house about 18 years ago and one of the windows has began to leak a little tonight as its been raining.
Its a small window with an oblong opening window at the top and a larger square opening windows below it.
The leak is coming in from the top of the square window and dripping down onto the windowsill below it and dribbling down the inside of the window itself.
Does anyone know the best way to get this fixed and also to have the other windows checked?
I assume over time the seals on the insides of the windows where they clamp closed when the window is shut to the frame wear out or perish over time? Is it possible to have these replaced somehow?
Sorry if this is a daft question, its the first time its ever happened.
