Double sided tape for back plate mounting
26 Jul 2007
I am moving my Tuniq Tower 120 CPU Cooler from one MB to another. Where can I find some suitable thick double sided tape to fix the mounting back plate onto the new motherboard? I would like something with a bit of thickness to cushion any solder points on the back of the new motherboard from the back plate.
Any ideas?
Thanks
The manufacturers of Sellotape do a double-sided sticky foam type stuff that comes on a roll. I used it for hanging photos when I rented a flat and couldn't hammer nails into the wall! It's cheap and strong, should do the trick.
