I don't know how many are dovecot savvy here but I thought I would ask as I am getting desperate!
Ok, so I updated today and it brought in the new dovecot 2.1.1. I had to create a new dovecot SSL file to get it to keep working, and now with that fixed it won't authenticate over imap.
My dovecot -n is:
and the error message I am recieving is:
the line in question is:
Mar 1 13:03:36 localhost dovecot: imap-login: Disconnected (no auth attempts in 0 secs): rip=195.171.99.130, lip=78.110.170.148
Can anyone shed any light on this? The errors happen with thunderbird imap and also my roundcube configuration.
My dovecot -n is:
Code:
# 2.1.1: /etc/dovecot/dovecot.conf
# OS: Linux 3.2.8-1-ARCH i686 ext4
auth_mechanisms = plain digest-md5 cram-md5
auth_socket_path = /var/run/dovecot/auth-userdb
default_internal_user = vmail
disable_plaintext_auth = no
mail_location = maildir:/var/vmail/%d/%n/Maildir
managesieve_notify_capability = mailto
managesieve_sieve_capability = fileinto reject envelope encoded-character vacation subaddress comparator-i;ascii-numeric relational regex imap4flags copy include variables body enotify environment mailbox date ihave
passdb {
args = /etc/dovecot/dovecot-sql.conf.ext
driver = sql
postmaster_address = [email protected]
protocols = imap
service auth {
unix_listener /var/spool/postfix/private/auth {
group = postfix
mode = 0666
user = postfix
unix_listener auth-userdb {
mode = 0600
user = vmail
service imap-login {
inet_listener imap {
port = 0
inet_listener imaps {
ssl = no
service pop3-login {
inet_listener pop3s {
ssl = no
ssl_cert = </etc/ssl/certs/dovecot.pem
ssl_key = </etc/ssl/private/dovecot.pem
userdb {
args = uid=5000 gid=5000 home=/var/vmail/%d/%n/Maildir allow_all_users=yes
driver = static
protocol lda {
mail_plugins = sieve
Code:
ays=0.06/0/0/0.04, dsn=2.0.0, status=sent (delivered via dovecot service)
Mar 1 13:02:06 localhost postfix/qmgr[998]: 52ABB203E3: removed
Mar 1 13:02:24 localhost postfix/smtpd[1527]: connect from merlin.infradead.org[205.233.59.134]
Mar 1 13:02:24 localhost postfix/smtpd[1527]: B109B203E3: client=merlin.infradead.org[205.233.59.134]
Mar 1 13:02:24 localhost postfix/cleanup[1537]: B109B203E3: message-id=<[email protected]>
Mar 1 13:02:24 localhost postfix/qmgr[998]: B109B203E3: from=<linux-arm-kernel-bounces+ml=communistcode.co.uk@lists.infradead.org>, size=4999, nrcpt=1 (queue active)
Mar 1 13:02:24 localhost dovecot: lda([email protected]): msgid=<[email protected]>: saved mail to INBOX
Mar 1 13:02:24 localhost postfix/pipe[1540]: B109B203E3: to=<[email protected]>, relay=dovecot, delay=0.15, delays=0.11/0/0/0.04, dsn=2.0.0, status=sent (delivered via dovecot service)
Mar 1 13:02:24 localhost postfix/qmgr[998]: B109B203E3: removed
Mar 1 13:02:25 localhost postfix/smtpd[1527]: disconnect from merlin.infradead.org[205.233.59.134]
