Need to get this room finished pronto. Lighting is what's stopping it all. We had talked about fitting Downlights with LED bulbs in a warm white with a dimmer.
Babies spend quite a lot of time laying on their backs and looking up at the ceiling. Try lying on your back with your eyes wide open directly under a lamp for a bit and see how comfortable it is
Babies rooms need soft / indirect dimmable lighting
Also consider now what you're going to do in terms of getting up to do night feeds - a dim nightlight is excellent for this, no need to turn any other lights on when getting up at night.
[Edit] We have a pair of these, one in the hallway and one in the kiddies bedroom. They are quite bright so have a strip of electrical tape around the bottom to reduce the light output - http://www.argos.co.uk/static/Product/partNumber/9829079.htm
Ha, I'm in the same boat...6 weeks to go and we have no flooring upstairs but need to get baby room sorted ASAP. We decided on LED for majority accept baby's room as they look up so much. Going for traditional shaded lamp in centre of room and a desk lamp
Dimming is a must. Bright lights will wake the baby or add discomfort. Ours tend to be a sleep zombie, much likes myself, when feeding in the night and goes back to sleep easily but not if there are loud Moises or bright lights.
We have got down lights with dimmable LED lights. We have the daytime style lights also so nice white light.
Will try get some photos uploaded tonight to show you but I think they look great!
Is this a baby that is due or one already born and ond enough to sleep in their own room?
I ask this as Eleanor is now 13 weeks old and still sleeping in our room and will be for another 3 months as this is what is recommend, she is already sleeping throughout the night so night feeds are not a problem but a dimmable light whatever you choose is a must if you do eventually need to get up in the night for them and not disturb too much.
