- 23 May 2006
Hi
I'm thinking of having led downlights fitted in the kitchen, however I don't know the best layout for the lights or which ones are best, I was looking at the hybrid 9 ones
The room layout is slightly L shaped
The work surfaces are 600mm, so would I need 4 lights in a square shape where it's narrower or could I get away with just two in line with the work surface?
I've included a plan
https://ibb.co/bLMCgG
