Downloading Problem
28 Aug 2003
lost on a big planet.
Hi,
Having a bit of a problem downloading files from my PC, this started at the weekend when i was trying to download some mods for a game.
The download box will pop up and after a couple of secounds it will stop downloading, and after a while it times out,i can still surf the net at this time.
This happens even if i try to download the same file from differant sites.
I can still download fine from my laptop ( the same files), with out a problem which makes me think its the PC.
The PC is connected to a router, wired, and the laptop is wireless.
Has any one got any ideas before i reinstall windows as i think this could be the only way to sort it.
Thanks for the link to the program YoungBlood, that seems to do the trick, downloading fine with it, just need to fix the problem of downloading with out it now.
