I need to reduce the size of my case but want to keep my hardware set-up and configuration. The set up is,
Can anyone steer me toward a suitable case to replace the HAF X which measures 22" x 10" (560mm x 250mm) maximum. The Above mainboard is a E-ATX Form Factor; 30.5cm x 26.4cm
I would also prefer as silent running as possible, I will be replacing the GFX card as it will no longer be used for gaming
All advice and comments appreciated.
- Gigabyte G1 Sniper 2 Mainboard.
- Intel i7-2700k Proccessor
- 16Gb Ram
- Crucial M4 256Gb SSD Status Healthy
- Samsung HD103SJ 1TB F3 EcoGreen SATA 7200rpm
- MSI AMD Radeon R9 290 Series. GFX
- Coolermaster HAF X Full Tower.
- Coolermaster Ultimate 1100W USP Power Supply Unit.
- LG Optical DVD Reader.
