Downsizing...need some help!
2 May 2011
Woking
Morning guys,
I'm downsizing my PC. I could do with some advice on decent small cases.
I've currently got a Fractal R2, and it's huge (L 53, W 21, H 44). I need something much smaller, particularly in length, so it fits neatly under my desk. I was looking at slim cases, but I'm concerned that I wouldn't be able to re-house my PC in it.
I have the following:
Micro-ATX motherboard (MSI Mortar 550M) w/ Ryzen 3600
Corsair H80i for the CPU
GTX 970, which has a 240 mm rad and a small reservoir/pump combo
Power supply
2 x SSDs
Maybe 1 x 3.5" SSD
My budget is max £75. Any ideas??
Thanks in advance :)
Raijintek Thetis should fit all your parts in 36x21x37. Won't find many cases shorter than that.
Not sure about reservoir, could attach it somewhere above PSU
https://www.overclockers.co.uk/raijintek-thetis-aluminium-atx-cube-silver-window-ca-03b-rt.html
Raijintek Styx will be a tighter fit
https://www.overclockers.co.uk/raijintek-styx-windowed-white-micro-atx-case-ca-03l-rt.html
Those are beautiful! How would I know if I’d need to downsize my PSU if I’m looking at options like this?
in this case, would the 240 rad go up top and the fan for the h80 go at the rear?
