Downsizing PC advice
15 Jul 2020
Hi,
I'm looking to downsize my pc to make it more travel friendly, I'm trying to work out if my current PC components will work with a new case. The Main part I am really concerned about is my CPU cooler.
I currently have this build:
Case: CORSAIR CRYSTAL SERIES 570X
AMD Ryzen 9 3950X
ASUS TUF X570-PLUS GAMING
64GB Corsair VENGEANCE DDR4 3000MHz
512GB INTEL 660p M.2 NVMe PCIe SSD
CORSAIR 650W TXm SERIES SEMI-MODULAR 80 PLUS, GOLD ULTRA QUIET
FrostFlow 240 Series cpu cooler
2x 2.5" sata SSDs
GPU: MSI 1070 gaming x
The case I am looking at is this:
www.overclockers.co.uk/jonsbo-u4-black-window-mini-tower-case-ca-00x-jb.html
I am open to other case recommendations but aside from the riotoro cr1080 I have not found anything quite as compact.
Thanks! :)
What context is there, that you need it to be portable? A full ATX case with a glass window is still going to be pretty bulky and heavy.
A 3950X with a 1070 isn't what I'd be wanting to do that with.
Yea ideally I need something that I can travel with on the train using a travel case like this:
https://imgur.com/a/R3wuVlU
The GPU would be taken out and boxed in a separate bag before travel to stop it getting damaged or to stop it damaging anything else.
it doesn't need to be portable day to day, but I would like a case/setup that would allow me to move and travel every 3-6 months with.
Hi and welcome to the forums. :)
That Jonsbo U4 may look good but I feel sorry for any components put in it. With only a single 120mm rear exhaust and extremely restricted front vents on a single side that is nothing less than a hot box that will cook your components. There are much better cases available for a similar price but if you are serious about going smaller get a smaller motherboard and go for a m-ATX or ITX case.
Every 3 - 6 months is a lot easier, for sure. A lot of the weight comes from the components rather than only the case. Once you go for something compact (usually MATX/ITX) and aluminium then there's only so much lighter it can get.
With the cooler you'd need to check the case can support a radiator of that size, not all fan placements are wide enough to support that, it's usually via the top or rear mounts. I'm not sure, but I can't see how it'd fit in that case.
