Welcome to the µTorrent Port Checker.
A test will be performed on your computer to check if the specified port is opened.
Checking port XXXXX on xx.xx.xx.xx
OK! Port xxxxxx is open and accepting connections.
You will be able to receive incoming BitTorrent connections.
I find Slackware 11 is the fastest swarm I've seen. I downloaded at about 4 MiB/s and am uploading at about 2 MiB/s with all settings set to unlimited.bledd. said:check with a really fast torrent like a linux release -ubuntu![]()
Camalot said:I've never got above 20, ever!
1mb pipex.
1mb pipex.
1mb pipex.
seems odd how Azerues hogged your PC thats 2x the speed of mine (kinda) when it doesn't bother mine at all?tweakinfreak said:There are some good utorrent tweak advice sites, I set my upload to 25 and I down load at 10mbps ......full bandwidth at times!!
Takes a while to get going on utorrent but tis the best by imo....azerues just hogged processes and slowed my pc down
Depends A LOT on how many torents you have active.VeNT said:seems odd how Azerues hogged your PC thats 2x the speed of mine (kinda) when it doesn't bother mine at all?
BillytheImpaler said:WHy do you guys limit up speed? It's not like it hurts your down speed.
