DP 3M cable that will run at 100hrz
28 Sep 2005
Hi Guys
Just got my ACER Predator X34 and I need a 3meter cable that will work at
3,440 x 1,440 @ 100Hrz . Just got one off Amazon and will not run at 100Hrz
Got any links to a 3M cable that will work ?
PS... This monitor blows your socks off!! ;)
Carl
Are you sure the monitor is configured to run at 100hz? Do you know if the DP cable is the same DP version as that of the monitor?
I'm using 3m UGREEN cable with that monitor and it works perfectly at 100hz with gsync enabled.
Paid about £7.50.
Paid about £7.50.
Thats CRAZY as I also purchase a UGREEN 3 meter cable and I can not get it to run @ 100Hrz But swap out to the original cable and 100 Hrz option in Nvidia control panel is there.. WTF!
