ok thanks, so no difference in the quality of them are all d p cable the the same none better than the other?
thanks.
i do not need any more than 2m so any d p cable will be ok?
If you want longer than 3M then look at fibre-optic cables.
thank you very helpful information Quartz .Any DP 1.4 cable. And if you watch the video you will see that some are capable of the upcoming DP 2.0 standard.
