Hey, I got a GTX 970 and 3 Monitors, the first one is connected by DVI-I connection with a VGA to DVI-I connection, which works perfectly with the other two, the other one is connected by a DP connection with a VGA to DP adapter, and the third one is connected by a DVI-D cable.
Weirdly the DP and DVI-D ports aren't running together, if I plug in the DVI-D cable and afterwards the DP, only the DVI-D Monitor works and its like that the other way around too. The DVI-I Monitor doesn't seem being affected by this at all.
Also it has nothing to do with the Monitors by itself, but more with the ports/Graphics Card, because I can switch the DVI-I and DP Monitor connections around and then the problem is at the other Monitor.
What I tried is:
- switching around the cables
- trying to find the Monitors on my Computer but it doesn't find anything (just says that it doesn't find any more Monitors)
- searched through the internet, but didn't find any solution to this problem, which is why I'm asking this question
My graphics card drivers are up to date and the ones of my Monitors too
Hope someone can help me with this problem!
What I tried is:
