DP to HDMI - Max Resolution
25 Sep 2006
Hi,
Hooked up my MBP to a new 29" display via DP to HDMI but looks like the max resolution output is 1920 x 1080, rather than 2560 x 1080 I need.
Is there any software update or patch for this or do I just need a mini DP to DP lead instead?
(2010 13" MBP)
Thanks,
BennyC
Would a Mod mind moving this to Mac Software please? :)
I've had to use a free trial of SwitchResX to get my MBP to output 2540 x 1080, even with a mDP to DP cable and also disable System Integrity. Otherwise I was stuck at around 1900 x 1080 still.
Surely there must be a better solution? or is it just my hardware limitation?
http://www.madrau.com/support/support/srx_1011.html
Thanks.
Just a guess here but I assume it's probably Apple not configuring the device to run that resolution. It's not a standard resolution and as such may not be designed to scale to it.
