Dragon NaturallySpeaking
Permabanned
3 Jan 2009
Derby
I am not sure where to post this.
I am just wondering if Dragon NaturallySpeaking is any good and do it rely work and if they any other software that is more good than that?
And all so is it ever going to be done so it can work on vista64
Thanks for any help/info on this
I used it briefly at uni due to it supposedly helping people with dyslexia. It was horrible. I don't know if my then current mic was just so **** it couldn't pick up properly but you would say one thing and something different would come up.
Reportedly though it is much better than Vista's own software so if it works for you, try it (trial version may be available).
Thanks, I do know that you have to use it for a bit so that it type what you say and that will take a bit off time.
btw, Do you know if they going to do it any time soon so it work on vista64?
Sorry, no I don't. My interest in it stopped when it wouldn't work and failed numerous times while trying to set it up. However, maybe it will be worth looking at reviews for newer versions than 9 (I think is the one I used)?
Ok, Well thanks for all the info guys.
I'll give it a go and then let you all know what it is like when I do get it to work on vista 64
