- 30 Nov 2010
- UK
Hi,
Thinking about putting in a drain like this, so basically I can just undo the stop cap underneath the case to drain the loop. My question is will having a tube of around 15cm coming of the reservoir down to the drain port be a issue for flow as it the fluid will just flow down and then stop.
EDIT although I am using a T at the end, there will be nothing coming out the other side. This will just be a seperate line coming of the res just to allow me to drain.
