Bought one of theseback in Aug 12 and have had it fitted to my computer since then.
Am going to have to break into the loop as need to replace my 7970 which has gone pop on me.
At present I do not have a drain in the loop but was going to add one.
After reading up on here have decided upon adding a quick release coupling to the bottom of the loop for future draining.
Only question is what fittings do I need for this?
May also replace teh tubing as it is the same that was fitted originally and is looking rather 'cloudy' at present. Any recommends for decent tubing too?
