- 22 Feb 2014
Having recently installed a new patio that slopes away from my property.
I thought it would be easy enough when cleaning it to sweep towards the drain at the top of the patio, this is proving quite hard work though.
So I am now thinking of installing a drain channel at the bottom to stop the lawn becoming water logged if I sweep down the patio away from the property.
If I were to install a drain channel there is no easy way to connect to a soakaway or any existing drain channels.
What I could do is spread the drainage of the patio to the rest of the lawn.
how do I distribute the water over the rest of the lawn, is it simply a case of putting in perforated pipe under the lawn with the holes facing down ?
Unfortunately the lawn is also freshly laid (turf, 2 weeks old) so I would want to try and do this with a single pipe so that I only have to dig one channel and cause the least amount of disruption to the lawn possible.
Would this actually work though ?
