Drained loop - residual fluid???
7 Aug 2012
Hi, as per my previous post regarding the problem with leaky pump - I believe I might have resolved that issue. However, after draining the loop (I had to cut tubing to remove res/pump) there is still a tiny amount of residual fluid (Mayhems paste blue) in the remainder of the loop. Will this be ok to sit for a few days until I can get re-supplied with tubing? Daft question, as I assume it will be ok since the same fluid will be going back in, but wondered what the view of the more experienced among you would be.
