Draining loop, please provide me feedback
7 Aug 2013
Malta
At last everything has been deposited and ready to go.
Reader
Final version of my drain loop what do you think?
https://www.dropbox.com/s/0e2rxhod11d6utu/dada.png
I was am going to do the loop like this:
Compression fitting<T fitting 1 <Male To male<reservior
Male to Male
Bitspower Valve
Compression fitting
Clear Tubing to see if there will be any leaks from the valve
Compression fitting
Xspc Plug G 1/4< T-fitting <Xspc Plug G 1/4
What do you think about this setup,I pretty much like it. I can't simplify anymore the draining and creating a leak free system.
Looks good to me. The valve minimizes the amount of dead water in the system, otherwise it's a standard T-line. How long are you making the tubing?
Going to use the 7/16 tubing thru out the system nonethless the xpsc kit comes with some clear tubing... for now I don't know I just ordered the corsair 900D and I have to check. I want to easily drain it in a bowl effortless on my desk so I have to wait and see.
