Drains/ventilation query.
18 Oct 2002
"Sunny" Plymouth
Right, when we moved into this flat there was a second toilet in a small room by the back door, which we ripped out and turned into a wash room (washing machine, tumble drier, etc).
On the outside of the wall is a 4" vent pipe running up the wall and 2 foot further on from that is a manhole cover, the only feed into the manhole cover is our washroom and kitchen, no "organic" waste.
Does anybody know if this ventpipe is still needed? If i can chop it down i've got a bit more room to play with in the back yard (the pipe is just far enough away from the corner of the yard to be in the way!)
Cheers :) (trying to catch up on all the jobs i've been wanting to do for the last few months now!)
All sewers should have a vent of sorts to comply with building control. If you seal it there is nowhere for the gases/pressure to escape. Dont think you will have too many problems if you cut it off, as long as your other loo is on the same sewer and is vented
Bum :( Bathroom is on a different sewer, looks like i might have to make do with re-routing it somehow.
