- 26 Oct 2007
- Death Star or Mount Doom, it depends on the day.
According to the latest version of Cpu-Z my dram frqency is 400.8mhz. IS the correct for my ram?
No, CPU-Z reports actual frequency, all DDR RAM (DDR, DDR2, whatever) is effective of double actual.(cpu-z reports the ddr frequency, the ddr2 freqency is double that)
Try it and test but if possible stick within specs, iirc the E8400 has a 9x multi so you could get 3.6 Ghz out of it without overclocking the RAM, which should be more than enough for games at least.Ah ha! Tar. How do you know what is safe to take it upto
