DRAM setting help please
27 Dec 2009
I shall swap over from a previous forum here .. Had a CPU AIO pump fail .. replaced now ... then on boot had a date/time error ... so replaced the battery (now good) ... now it appears that my overclock and DRAM settings have gone and I have had these for years and working just fine .. have tried all afternoon to get it working without success .. Have kept the stock i7 6700k speeds to try and keep everything stable and no matter what I do .. this DRAM doesnt want to play ball .. error 55 DRAM not recognized ... anybody able to talk me through the manual settings for Team Group DDR4 3733 CL 18-20-20-39 1.35 volts and any other settings please .. I must be doing something wrong ... have tried XMP of course with no luck and tried manual settings with the same results. I have also tried each stick of ram to see if there was an error with either one and each will boot up to windows by itself. If I boot from a clean stock bios I get no errors but of course it's only running as at 2333
Ideally I want to get back up to a 4.4 ghz overclock with DRAM at stock speeds
CPU: Core i7 6700K
Mobo: Asus Maximus viii Extreme
