DRAM Termination Voltage?
18 Sep 2005
Hi,
I've installed x2 2GB sticks from a 6GB OCZ kit (OCZ3G1333LV6GK) onto a Gigabyte GA-H55M-UD2H motherboard, however there are no XMP profiles selectable in the bios and instead it's using what look like fail safe SPD settings running the memory at 1066Mhz @ 1.5v.
Now I can set the memory up to run at it's default 1333Mhz speed @ 1.65v, however there are additional voltage settings for the memory which I assume should also be changed:
DRAM Voltage - auto set 1.5v
DRAM Termination - auto set 0.750v
Ch-A Data VRef. - auto set 0.750v
Ch-B Data VRef. - auto set 0.750v
Ch-A Address VRef. - auto set 0.750v
Ch-B Address VRef. - auto set 0.750v
Along with DRAM termination voltage there are 5 other voltage settings (none of which I understand) however it looks like they should be set to 50% of the DRAM Voltage. Is this right and therefore if I set the voltage to 1.65v should I also be increasing the other 5 settings to 0.825v?
Many thanks,
