Draw me a box
1 Sep 2007
Doing an NVQ at work and need to give a plan of my store as some of my work.
Havnt got a ruler and dont know if its possible to do it on here.
It needs to be exact - every 2m = 1cm scale. So if I measured it with a ruler, it would be spot on.
Heres the measurements if someone could do it for me please that would be awesome! :D
Length: 30m
Width : 20m
Height : 15m
Then I can send it her in an email.
Also put the measurements by each side.
I will love you if you do this :D
Are you going to draw inside the box? If it's only a cuboid you need surely she can get the exact same information form the L/W/H you provided?
ok... makes sense now, have you got nothing that can measure? Like a tape measure or something?
If you don't find anything else use google sketchup
Only did it because I was bored during a Pro Engineer sesh...:p
EDIT : Just realised that that might not be much use. Only gives you an idea of the scale of it really. Its not exact measurements...
Very kind of you to do that...but I dont mean that as a box...
like a 2d birdseye view.
eg :
: : 15m
30m
