Hi, just got my plusnet all up and running. Got the TG582n. I'm looking for a reliable all in 1 solution for fibre 80/20. I've seen the 2760 with built in vdsl2 and I am tempted by it. Having scouted around on here all I can find is various related topics about asus routers being a bit flaky with vdsl. I would like dual band 5Ghz but it really boils down to something that just works. N will do fine, The gigabit ports make it simple as I am hardwired to pc and bedroom. The bedroom being the area I would like decent wifi so I might consider getting the 2760 router without wireless and use this.
but I haven't really decided if A the 2760 will do the job and if its wifi is any good for streaming through concrete to the bedroom
If anyone has any suggestions, I'll be happy to receive. failing that I will do a little more digging around before I spend the £££
.If anyone has any suggestions, I'll be happy to receive. failing that I will do a little more digging around before I spend the £££
