Draytek ap 902c and 1000c low Wi-Fi speeds
23 May 2015
Currently have a 2762ac router hooked up with these ap and whilst speeds from router are fine they are diabolical on ap.
should be getting 250 but getting 20 mb/s at best and only 9 mb/s on 5 ghz channel.
I used the wizard for each ap and have them in ap mode.
Not sure what I’m doing wrong as I have them directly connected using cat6 cable to router.
Direct cable connection from ap to pc is fine with full speed.
Any advice much appreciated!
Are you managing them centrally via the Router?
I've got a 2862ac and a AP910C and I struggled even with performance of the webpage of the AP910C when managed centrally. I ended up resetting it and running it standalone but with matching SSIDs, and haven't any issues since.
When you say managed centrally I’m not sure what you mean
I’ve only connected them through the router and access the portal page of the ap and not the router when making changes.
I’d be happy to give your set up a go providing you gave me details of exactly how,
Thanks for your help
